The Cube build process in OFSAA Infrastructure contains the following steps:
· Generating an aggregate DATA file containing the measure values for each dimension leaf that are part of the cube definition. This is performed by the AGGREGATE DATA component task within the batch definition.
· Creating the cube outline on Essbase server. This is performed by the CREATE CUBE component task within the batch definition.
· Loading the data to the cube. This is performed by the CREATE CUBE task within the batch definition
