Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22214 - Message Copy Queue Utilization
Alarm Group:
DIAM
Description:
The DA-MP's Message Copy queue utilization is approaching its maximum capacity.
Severity:
Minor, Major, Critical
Instance:
N/A
HA Score:
Normal
Auto Clear Seconds:
0 (zero)
OID:
eagleXgDiameterMsgCopyQueueUtilNotify
Recovery:
  1. Reduce traffic to the MP.
  2. Verify that no network issues exist between the DA-MP and the intended DAS peer(s).
  3. Verify that the intended DAS peer has sufficient capacity to process the traffic load being routed to it.
  4. If the problem persists, it is recommended to contact My Oracle Support (MOS).
