Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22017 - Route List Alarm Aggregation Threshold
Alarm Group:
DIAM
Description:
This alarm occurs when there are a ‘Critical’ number of Route List alarms for the Network Element.
The alarm thresholds are configurable using the Alarm Threshold Options tab on Diameter > Configuration > System Options.
Severity:
Critical
Instance:
<NetworkElement>
HA Score:
Normal
Auto Clear Seconds:
0 (zero)
OID:
eagleXgDiameterRouteListUnavailableThresholdReachedNotify
Recovery:
  1. Use Main Menu > Diameter > Maintenance > Route Lists to monitor Route List status.
  2. Verify that IP network connectivity exists between the MP server and the peers.
  3. Check the event history logs for additional DIAM events or alarms from this MP server.
  4. Verify that the peers in the Route List are not under maintenance.
  5. It is recommended to contact My Oracle Support (MOS) for assistance.
