19272 - TCAP active dialogue utilization
- Alarm Group:
- SS7
- Description:
- Severity:
- Minor, Major, Critical
- Instance:
- Application name
- HA Score:
- Normal
- Auto Clear Seconds:
- 0 (alarm does not clear automatically)
- OID:
- awpss7TcapActiveDialogueUtilNotify
Recovery:
The percent utilization of the MP's dialogue table
is approaching maximum capacity. This alarm indicates that the number of active
dialogues on the MP
server
is higher than expected.
If this problem persists and the dialogue table
reaches 100% utilization, all new messages will be discarded. This alarm should
not normally occur when no other congestion alarms are asserted. This condition
may be caused by any of the following:
- the incoming plus outgoing rate of new dialogues
is higher than expected (possibly due to poor load balancing across MP
servers,
or too few MP
servers
to handle the load)
- the duration of the dialogues is longer than
expected
- both the rate and duration are higher than
expected
- a software problem is preventing removal of
completed dialogues
It is recommended to contact My Oracle Support (MOS) for assistance if needed.
