Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
10125 - Server Group Upgrade Failed
Alarm Group:
LOG
Description:
Server group upgrade operation failed.
Severity:
Major
Instance:
<ServerGroupName>
HA Score:
Normal
Auto Clear Seconds
0 (zero)
OID:
dbcTekelecLogSgUpgradeFailAlmNotify
Recovery
  1. If the problem persists, it is recommended to contact My Oracle Support (MOS).
