Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
19269 - Dialogue aborted by remote TCAP peer
Event Type:
SS7
Description:
Severity:
Info
Instance:
Application name
HA Score:
Normal
Throttle Seconds:
30
OID:
awpss7TcapDialogueAbortByRemoteNotify
Recovery:
  1. This event indicates that a remote TCAP peer has aborted a dialogue.
  2. The event additional information field includes:
    • the abort reason
    • the first 80 octets of the message starting with the MTP3 routing label
  3. The message data can be used to determine the source of the U-Abort or P-Abort message.
  4. It is recommended to contact My Oracle Support (MOS) for assistance if needed.
