10200 - Remote database reinitialization in progress
- Alarm Group:
- CFG
- Description:
- The remote database reinitialization is in
progress. This alarm is raised on the active NOAM
server
for the
server
being added to the
server
group.
- Severity:
- Minor
- Instance:
- <hostname of remote
server>
- HA Score:
- Normal
- Auto Clear Seconds:
- This alarm does not autoclear.
- OID:
- apwSgDbReinitNotify
Recovery:
Check to see that the remote
server
is configured.
Make sure the remote
server
is responding to network connections.
If this does not clear the alarm, delete this
server
from the
server
group.
If the problem persists, it is recommended to
contact
My Oracle Support (MOS).
