22075 - Message is not routed to Application
- Alarm Group:
- DIAM
- Description:
- ART Rule-X was selected, but message was not
routed because
DSR
Application is disabled or not available.
- Severity:
- Major
- Instance:
- <DSR Application Name>
- HA Score:
- Normal
- Auto Clear Seconds:
- 0
- OID:
- eagleXgDiameterArtMatchAppUnavailableNotify
Recovery:
Check the Application Status by navigating to
and Enable the application
if the Admin State of the DSR application is Disabled for a particular DA-MP(s)
which raised the alarm.
If the Application is Enabled for a particular
DA-MP, but the Operational Status is Unavailable or Degraded, then refer to the
Operational Reason and rectify it accordingly.
If the problem persists, it is recommended to
contact My Oracle Support (MOS).
