31114 - DB replication over SOAP has failed
- Alarm Group:
- REPL
- Description:
- Database replication of configuration data via
SOAP has failed.
- Severity:
- Minor
- Instance:
- May include AlarmLocation, AlarmId, AlarmState,
AlarmSeverity, and bindVarNamesValueStr
- HA Score:
- Normal
- Auto Clear Seconds:
- 3600
- OID:
- comcolDbReplicationSoapFaultNotify
Recovery:
This alarm indicates a SOAP subsystem is unable to
connect to a server, due to networking issues or because the server is not
available. Investigate the status of the server and verify network
connectivity.
If no issues with network connectivity or the server
are found and the problem persists, it is recommended to contact
My Oracle Support (MOS).
