Go to primary content
Diameter Signaling Router Alarms and KPIs
Release 8.2
E89015-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Generating a report of active alarms
Use this procedure to generate a report.
  1. Click Alarms & Events > View Active.
  2. Specify filter criteria, if necessary, and click Go.
    The active alarms are displayed according to the specified criteria. Alternately, you can select multiple rows and generate a report using those. To select multiple rows, press and hold Ctrl as you click to select specific rows.
  3. Click Report.
    The View Active Report can be printed or saved to a file.
  4. Click Print to print the report.
  5. Click Save to save the report to a file.
