Go to primary content
Diameter Signaling Router Policy and Charging Application
Release 8.2
E89000
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Identifying the Diameter network and properties for Online Charging DRA
  1. Identify and log the hardware profile type for each of the DA-MP Servers (PCA).
  2. Identify and log the number of Online Charging clients (CTFs) and Online Charging servers (OCSs) in the network.
  3. Identify and log the diameter attributes for all the Online Charging clients and Online Charging servers in the network - FQDN, Realm, IP address.
  4. Identify and log the type of diameter Transport Protocol needed for all the Online Charging clients and Online Charging servers - TCP/SCTP..
  5. Identify and log the type of diameter connection mode needed for all the Online Charging clients and Online Charging servers - Responder/Initiator/Responder-Initiator.
  6. Identify and log the Peer Node Identification for all the Online Charging clients and Online Charging servers - IP Address/FQDN.
  7. Identify and log the route groups and route lists needed for Online Charging servers.
  8. Identify and log the number of peer route tables and peer route rules needed for the diameter configuration for Online Charging servers
  9. Identify and log the number of Application Route Table entries and for OC-DRA message processing.
  10. Identify and log the TSA used for local nodes if IPFE is used.
