Diameter Common configuration must be done before PCA configuration can be performed.
Use the explanations and procedures in the Diameter Common configuration help and the Diameter Common User's Guide to complete the Diameter Common configuration, including the Diameter Common components needed for use with PCA.
SOAM Diameter Common Configuration
Diameter Common configuration for MP Profile assignment for PCA is done from the SOAM GUI .
