On the Active SOAM, click Policy and Charging > Configuration > Policy DRA > PCRFs.
The Policy and Charging > Configuration > Policy DRA > PCRFs page appears. The page displays a list of the configured PCRF Peer Nodes that are used when a new subscriber binding is created.
Click in the Comments field of the row to select the PCRF to edit.
DO NOT click the blue PCRF Peer Node Name (except to see the configuration of the Peer Node). The blue color indicates a hyper-link that opens the Diameter > Configuration > Peer Nodes [Filtered] page to display the configuration information for the Peer Node.
Edit the Comments field for the selected PCRF.
The PCRF Peer Node name cannot be changed.
Click:
OK to save the change and return to the Policy and Charging > Configuration > Policy DRA > PCRFs page.
Apply to save the change and remain on this page.
Cancel to return to the Policy and Charging > Configuration > Policy DRA > PCRFs page without saving any changes.
If Apply or OK is clicked and the selected PCRF Peer Node Name entry no longer exists (was deleted by another user), an error message appears.
