Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Customizing the Login Message
Before logging in, the System Login page displays. You can create a login message that displays just below the Log In button on the System Login page.
Figure 2-1 Oracle System Login
  1. From the Main Menu, click Administration > General Options.
  2. Locate LoginMessage in the Variable column.
  3. Enter the login message text in the Value column.
  4. Click OK or Apply to submit the information.
    A status message displays at the top of the Configuration Administration page to inform you if the operation was successful.
The next time you log into the user interface, the login message text displays.
