Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Filter Control Elements
This table describes filter control elements of the user interface.
Table 2-6 Filter Control Elements
Operator Description
= Displays an exact match.
!= Displays all records that do not match the specified filter parameter value.
> Displays all records with a parameter value that is greater than the specified value.
>= Displays all records with a parameter value that is greater than or equal to the specified value.
< Displays all records with a parameter value that is less than the specified value.
<= Displays all records with a parameter value that is less than or equal to the specified value.
Like Enables you to use an asterisk (*) as a wildcard as part of the filter parameter value.
Is Null Displays all records that have a value of Is Null in the specified field.
Not all filterable fields support all operators. Only the supported operators are available for you to select.
