Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Contents
Previous
Next
Enabling SoR
Use this task to enable SoR on the SO. You can also pause updates using this task.
Navigate to
Diameter
Maintenance
Applications
Select
DCA_SOR
Click
Enable
The SoR instance is added to the GUI menu.
