Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Optional Layout Element Toolbar
The optional layout element toolbar displays in the Page Control Area of the GUI.
Figure 2-10 Optional Layout Element Toolbar
The toolbar displays different elements depending on which GUI page is selected. The elements of the toolbar that can display include:
  • Filter – Allows you to filter data in a table.
  • Errors – Displays errors associated with the work area.
  • Info – Displays information messages associated with the work area.
  • Status – Displays short status updates associated with the main work area.
  • Warning – Displays warnings associated with the work area.
