Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
SoR Functions within the DCA Framework
DCA lets you access with the following functions:
  • Use Custom MEALS to view a list of any previously configured SoR custom defined measurements and events (SO or NO view GUI page). Use this page to insert, edit, and delete Custom MEALS.
  • Select General Options from the NO to specify the Perl Subroutine for Diameter Request and Answer. From the SO, use General Options to view the Perl Subroutine specified for Diameter request and answer in read-only mode.
  • Select Trial MPs Assignment to specify which MPs run the trial version of an application. If no trial version of an application configured in the system, the trial MPs will run the production version (if any exist). If there is a trial application version configured in the system, but no trial MPs is specified, a warning message is generated. From the SO, use this page to view which MPs run the trial version of an application. The page is accessible in read-only mode.
  • Use Application Control from the NO to:
    • List all application versions configured in the system
    • Insert a new application version
    • Copy and modify an existing application version
    • Export an application version entirely (business logic + provisioned data from the NO)
    • Export only the NO provisioned data of an application version
    • Import a previously exported application version (business logic + NO provisioned data)
    • Import only the NO provisioned data to an existing application version
    • Access the application version configuration tables
    • Access a flowchart of an application version
    • Delete an existing application version
    • Change the status of an application version (Development, Trial, Production, Archived)
  • Use Application Control from the SO to:
    • Export only the SO provisioned data of an application version
    • Import only the SO provisioned data to an existing application version
    • Access a flowchart of an application version (read-only)
  • Use System Options from the SO (only) to enable the configuration of the DSR application parameters that are:
    • Relevant to the operational status unavailable
    • Relevant to the case when the DRL resources are exhausted
    • Relevant to the run-time error
    • Realm and FQDN values that are placed in Answer message generated by the DCA
