Go to primary content
Diameter Signaling Router Roaming Steering
Release 8.2
E89014
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Max Records Per Page Controls
Max Records Per Page is used to control the maximum number of records displayed in the page area. If a page uses pagination, the value of Max Records Per Page is used. Use this procedure to change the Max Records Per Page.
  1. From the Main Menu, click Administration > General Options.
  2. Change the value of the MaxRecordsPerPage variable.
    Maximum Records Per Page has a range of values from 10 to 100 records. The default value is 20.
  3. Click OK or Apply.
    OK saves the change and returns to the previous page.
    Apply saves the change and remains on the same page.
The maximum number of records displayed is changed.
