The Roaming Steering application allows home network operators to control and distribute registration traffic of their outbound roamers. To achieve this, the Roaming Steering application enables home network operators to define roaming steering policies for each group of roaming partners that are part of the same country. This functionality provides a roaming management solution to optimize roaming cooperation between operators, and it allows flexible network selection management for output roamers.
This document content provides information about the Roaming Steering application and functionality.
The Roaming Steering application menu options allow you to work with:
Roaming Steering is a Diameter Custom Application (DCA) Framework application. Like other DCA Framework applications, you can use Roaming Steering to work with the DCA Framework functions. If Roaming Steering is visible in the DCA Framework GUI menu, the application is already activated and provisioned.
