Configure Northbound Interface Traps
You can specify northbound interface (destination) fault trap receivers for northbound systems, such as a network management system, to receive forwarded SNMP trap fault notifications in either SDM format or International Telecommunication Union (ITU) X.733 format. You can also configure the heartbeat trap for the northbound interface, which is discussed later in this chapter.
The SDM fault manager function forwards trap notifications over the northbound interface to the configured trap receiver system(s).
The global ID must be the same for all nodes in the same SDM cluster. If there is more than one cluster in a network, each cluster must use a different global ID.In the following diagram, devices send all traps to the SDM server, which sorts them into events and alarms. Events are the aggregated list of all such messages while alarms record only the current state or latest event.
Figure 7-1 Device forwarding of SNMP trap fault notifications through SDM to a northbound trap receiver system
