Configure an Active Directory Domain Controller
This task is used to configure and active directory (AD) domain controller (domain server) for external user authentication.
- The Active Directory must be configured for LDAP over SSL if the Active Directory is enabled in Oracle Communications Session Delivery Manager.
- Active Directory must support version 5, if the Kerberos protocol is used.
- Each user object in your Active Directory must store the groups of each member using the memberOf attribute.
- Only child groups may be mapped to local groups when group nesting is in use. This limitation is due to the memberOf attribute not containing a recursive list of predecessors when nesting.
