Change Your User Password Use this task if you want to change the password that you used to login to the Oracle Communications Session Delivery Manager GUI. On the menu bar, select Tools > Passwords > Change user password. In the Change password dialog, complete the following fields: Name Description Current login user password The current user password used to login. New password The new password. Confirm new password The new password. Click OK
