Run Current Server as Standalone
You can configure a clustered server to be a standalone server by removing its cluster configuration.
- From the cluster management menu, select option 2, Run current host as a standalone. Press Enter to continue.
- Select option 1, Configure application server to a standalone server. Press Enter to continue.
- Select option 3, Quit out of cluster configuration.
- Select option 2, No.
