Upload a New Certificate
From SDM, you can upload a new X.509 certificate from your system to the SDM trust store.
  1. On the main menu, select Tools > Certificates.
  2. In the Certificates dialog box, click Import.
  3. In the Upload Certificate dialog box, complete the following fields:
    Name Description
    Name field The name of the X.509 certificate.
    File field The directory path of the certificate file on your system. Alternately, click Browse to navigate to the certificate on your system.
    The certificate appears in the Certificates dialog box with certificate name, issuer, start date, end date and serial number of the certificate. The changes are propagated to any cluster members.
