Configure Log Levels
You can configure log severity levels to filter the granularity of information presented in logs.
- On the menu bar, select Tools, Server Diagnostics.
 - In the Summary pane, click the Log Levels tab.
 - In the Logging Levels section, select All Files (default) or Per Individual File to choose the granularity for how files are logged.
If you selected
			 All
				Files, select from the following log levels in the
			 Log
				Level drop-down list.
DEBUG Debugging, informational, warning, and error logs are included. TRACE Trace, informational, warning, and error logs are included. INFO (Default) Informational, warning, and error logs are included. WARN Warning, and error logs are included. ERROR Error condition logs.  - If you selected Per Individual File, select a log level (refer to the previous step) for each log type that is retrieved. You can select Refresh to go back to the saved log file levels.
Click
			 Apply for your
			 logging level changes to be applied.
If the SDM restarts, all logging levels are reset back to the default (INFO).
