Configure When to Notify a User to Change Their Password
You can configure when the user is notified to change their password before it expires.
When the user logs into SDM, the system checks user credentials and the password expiry time for the user. If the password is due to expire, a warning is displayed that prompts the user to change their password.
- Expand the Security Manager slider and select .
- In the Password expiration notification panel, enter a value in the Days prior to password expiration field.
- Click Apply.
