PreviousNextJavaScript must be enabled to correctly display this content
Search for Alarms or Events by Specifying a Criteria
You can search for events and alarms by specifying one, some, or all of the search selection criteria. For example, you can select alarms for a specific IP address during a specified date-time range.
Expand the
Fault Manager slider and select from the following options:
Events
Alarms
In the alarms or events pane, click
Search.
In the
Filter search dialog box, complete the following fields:
Name
Description
Date from field
Click the calendar icon and select the month, year, and day and click
Today.
The chosen date to filter event data begins at 12:00 AM (midnight) on the specified date.
Date to field
Today.
