Specify the Global ID for Northbound Trap Receivers
The OC SDM global identifier configuration installation option must be configured on an Oracle Communications Session Delivery Manager server to create a unique global identifier (ID). When a device that is managed by Oracle Communications Session Delivery Manager forwards SNMP trap fault notifications, the global ID that you configure is used in this notification. When an administrator receives the SNMP trap fault notification on their northbound system, the originating device can be determined by viewing the global ID contained in the SNMP trap fault notification.
The global identifier must be the same for all nodes in a clustered system.
