Fault Management Configuration
Select option 4,
Fault Management configuration. Press Enter to continue.
[ ] 1 - Enter Passwords for default user accounts that will be created [Default] [ ] 2 - OC SDM global identifier configuration [ ] 3 - HTTP/HTTPS configuration [X] 4 - Fault Management configuration [ ] 5 - Quit setup
Select option 1,
Configure SNMP trap settings. Press Enter to continue.
[X] 1 - Configure SNMP trap settings [Default] [ ] 2 - Quit out of fault management configuration
Either enter the port number that your server will listen on for SNMP traps or press Enter to accept the default port of 162.
You cannot use a port number reserved for Oracle Communications Session Delivery Manager components.Enter the port number that Trap Relay should listen on: (1-65535) [162]
If prompted (you entered a port below 1024), enter the sudo password. Then re-enter the sudo password to confirm.
The sudo password is the NNCentral password to provide root permissions for listening for SNMP traps on ports lesser than port 1024. - Select option 5, Quit setup. Press Enter to continue.
Next Step
Start the Oracle Communications Session Delivery Manager server.
