Verify the Required SDM_localhost Entry is in the Hosts File
You must verify that the required
SDM_localhost entry is
in the
/etc/hosts file that
is used for internal server communication within a cluster, or for any
SDM server(s) in your
environment that do not rely on a domain name server (DNS).
The IP address that is used for theSDM_localhost entry on
each
SDM cluster member
must be registered on the network Domain Name Server (DNS). If this entry is
absent on the DNS server, DNS lookup timeouts occur, which can cause database
problems.
