Start the Session Delivery Manager Cluster Upgrade
The previous release of Oracle Communications Session Delivery Manager must manage at least one device to be upgraded successfully.
  1. Login to the master cluster server node as the root user.
  2. Navigate to the SDM installation bin directory.
    For example:
    cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
  3. Run the setup application with the setup.sh script. The setup.sh application determines that a migration of the application data needs to occur from the current version to 8.x. If you are migrating from SDM Release 7.5M3, specific plugin(s) may need to be installed based on the product devices (SBCs, E-SBCs, or both).
    ./setup.sh
    A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.
    WARNING:
    This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system.
  4. The data migration tool automatically detects the previous release. When you are prompted, select that you have a clustered system and use the following section to complete your upgrade.
