Adding New Members
- Select option 1, Add a new member. Press Enter to continue.
When you are prompted, enter the IP address of the node you are adding to the cluster. For example
Provide the IP address of the Host requiring membership to cluster. Member IP address [ ]
Do not enter the domain name server (DNS) name or the fully qualified domain name (FQDN) for the node. - Repeat steps to add additional nodes to the cluster.
- When done adding nodes, select option 3, Apply new cluster configuration. Press Enter to continue.
- Select option 3, Quit out of cluster configuration. Press Enter to continue.
- If this system is not part of the cluster, select option 2, No. Otherwise, select option 1, Yes. Press Enter to continue.
If you selected
Yes, enter the nncentral user name and nncentral password which other nodes of the cluster can use to SFTP files from this system. See the
Configure the NNCentral Account section if you need to configure an nncentral account.
The master server node in the SDM cluster must be started and fully operational before you can start the replica nodes.
