PreviousNextJavaScript must be enabled to correctly display this content
Start the Server after a Cluster Installation
Use this task if you are starting the
SDM server after the
cluster installation.
Ensure that the
application data migration from SDM 7.5M3 to SDM 8.x has successfully completed
before starting the cluster.
Once the
installation completes, switch to the nncentral user from the root user on any
cluster node. For example:
[root@myserver bin]# su nncentral
Navigate to the
Oracle Communications Session Delivery Manager installation bin directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Start
SDM with the
startnnc.sh script.
./startnnc.sh
After all services have started, the system is
ready for use. Do not attempt to log in until the console has indicated that
the web servers are up. If you are upgrading from 7.5M3, the plugin service
management system automatically uploads the plugins from the path you
identified earlier, and installs them. The console displays the number of
services started. For example:
Starting Back-End server now
27 of 27 services have started...
Starting Apache servers...
Servers and services started successfully. Web client access ready.
Once the system is
started, you can begin using
SDM by entering the
server host name or IP address, and port number in your web browser navigation
bar.
For example:
https://example.com:8443
Once this server
has started on this node and it is operational, you can start the other server
node(s).
