Shut Down the Session Delivery Manager Server
You can shut down the existing Oracle Communications Session Delivery Manager software version running on your system to install a new version of the software, restore a database or apply a software patch. If you are upgrading an SDM cluster, use these steps to shut down each server node in the cluster.
