Database Objects Not Migrated from SDM 7.5M3
When you upgrade from SDM 7.5M3 to SDM 8.0, not all data in the database can be carried over to the new database because of the way device information is structured and stored. The following types of data is not carried over to the new database:
| XSD File Name | Database Container | Description |
| alarms.xsd | alarms.dbxml | Maintains alarms for Fault Manager. |
| alarmsummaryview.xsd | ||
| events.xsd | events.dbxml | Maintains events for Fault Manager. |
| AuditTrail.xsd | AuditTrail.dbxml | Initiates audit logs for user actions. |
| DeviceStatDetails.xsd | DeviceStatDetails.dbxml | Reports the status of a device. For example, UP or DOWN. |
| DeviceConfigVersion.xsd | DeviceConfigVersion.dbxml | Maintains the configuration version for each device. |
| OfflineConfigVersion.xsd | OfflineConfigVersion.dbxml | Maintains Offline configuration version for each device. |
| KPIStatistics.xsd | KPIStatistics.dbxml | Maintains KPI details for each device. |
| <model>.xsd | All model containers | Maintains device configuration information. |
| AlarmSyncs.xsd | AlarmSync.dbxml | |
| ConfigArchive.xsd | ConfigArchive.dbxml | Maintains configuration archival information. |
| ConfigDataVariables.xsd | ConfigDataVariables.dbxml | Maintains information for any custom data variables that are created. |
| ConfigMapsClassic.xsd | ||
| DeviceCluster.xsd | DeviceCluster.dbxml | Maintains device cluster group details. |
| DeviceSpecificData.xsd | device | |
| DeviceTaskDetails.xsd | DeviceTaskDetails.dbxml | Maintains device provisioning log information. |
| Fault.xsd | Fault.dbxml | Maintains Sequence ID (SID) information for trap processing. |
| FSMLocks.xsd | FSMLocks.dbxml | Maintains resource lock information for trap and route set processing. |
| GlobalConfigView.xsd | ||
| LogMessages.xsd | LogMessages.dbxml | Maintains log messages. |
| NncBase.xsd | ||
| OfflineConfigView.xsd | OfflineConfigVersion.dbxml | |
| PollTask.xsd | PollTask.dbxml | Maintains poller data. |
| RcmConfig.xsd | RcmConfig.dbxml | Maintains reusable configuration information. |
| schedule.xsd | scheduler.dbxml | Maintains schedule information. |
| WorkOrder.xsd | WorkOrder.dbxml | Maintains work order information. |
| AO.xsd | AO.dbxml | |
| AOComposite.xsd | AOComposite.dbxml | |
| AOCapacity.xsd | AOCapacity.dbxml | |
| elasticity.dbxml | ||
| sipTrunkFed.dbxml | ||
| All Configuration view.dbxml |
