Session Delivery Manager Documentation Changes
The following tables describe the documentation changes for Oracle Communications Session Delivery Manager, Release 8.0.
With the introduction of the product plugin service and changes in the SDM product, only the Oracle Communications Session Delivery Manager Documentation Library appears in the About This Guide section of each SDM guide.Oracle Communications Session Delivery Manager Installation Guide
The Install Software Patches chapter was removed because this type of installation is no longer supported.| Current Chapter | Changes |
| Pre-Installation Tasks |
| Typical Installation |
| Custom Installation |
Oracle Communications Session Delivery Manager Administration Guide
| Current Chapter | Change |
| Implement Session Delivery Manager on Your Network | This chapter was added to provide information to help you decide how to implement SDM on your network and contains reorganized SDM component and cluster information that previously existed in past versions of this document and updated information. |
| Session Delivery Manager Application Overview | This chapter was added to provide information for accessing SDM, getting product plugin help, customizing the display, using tool tips, and changing the existing SDM user login. These sections were moved to this guide from the Oracle Communications Session Element Manager User Guide. |
| Manage Product Plugins | This chapter was added for the management of product plugins in SDM, which includes plugin installation guidelines and preparation, and plugin tasks. |
| Security Manager | Changes were made to privileges for user groups to accommodate the product plugin service. Also, improvements were made to the Configure External User Authentication section and subsections. The Determine the RADIUS Group that Devices are Using section was added. |
| Fault Manager | This chapter was moved to this
guide from the
Manager User Guide. The
Session Delivery Manager Traps section was updated
with new traps and other minor changes and improvements were made to this
chapter.
How an alarm trap group is selected was changed in the Customize Trap Severity Levels section and trap information was moved to the Configure Northbound Interface Traps chapter in this guide. |
| Manage Transport Layer Security Certificates | This chapter was added to provide information about uploading entity or trusted certificates to SDM for east-west peer SDM server communication, and for southbound communication with network function (NF) devices. |
Configure Northbound Interface Traps |
This chapter was previously named Northbound Interface. This chapter was also rewritten for clarity and information for configuring and managing fault notifications was moved to this chapter from the Fault Manager chapter of the Oracle Communications Session Element Manager User Guide. |
Monitor Session Delivery Manager Server Health and Disk Usage |
This chapter was previously named Health Monitor . The Add the Heartbeat Trap to Monitor Server Availability section was moved from the Oracle Communications Session Element Manager User guide to this guide and chapter and renamed Use the Health Monitor to Determine SDM Health. Also, the new Monitor SDM Server Disk Usage section and subsections were added to this chapter. |
| Session Delivery Manager Server Database Maintenance | This chapter was previously called Database Tasks. Several sections within this chapter were renamed, reorganized, and rewritten for clarity. |
Session Delivery Manager Server Cluster Maintenance |
This chapter was previously named High Availability. Several sections within this chapter were renamed, reorganized, and rewritten for clarity. |
| Appendix A: Available Session Delivery Manager Server Scripts | The ./bin/patchManagement.sh script and description was removed because this action is no longer supported on the SDM server. |
| Appendix B: Fault Trap Notification Contents | The information in this new appendix was from the previously named High Availability chapter. |
Oracle Communications Session Delivery Manager Security Guide
| Secure Installation Guidelines | The
Session Delivery Manager Product Plugin Service
section was added, which includes information about the plug-in service.
The Southbound Interface Transport Layer Security section was renamed Transport Layer Security Certificates and updated for changes to the Transport Layer Security (TLS) feature. Information was added to the Security Considerations for Developers section that directs users to the REST API for Oracle® Communications Session Delivery Manager Release 8.0 for more information about using the new REST Application Programming Interface (API) and a note was added that says the Oracle® Communications Session Element Manager SOAP/XML Provisioning API Guide, Release 8.0 is deprecated. |
REST API for Oracle Communications Session Delivery Manager Release 8.0
This new web-based documentation provides information for the supported REST APIs and how to use the REST API interface. The REST API interface allows a northbound client application, such as a network service orchestrator (NSO), to interact with Oracle Communications Session Delivery Manager and its supported product plug-ins.
