Add a Network Function with Devices
When preparing to use Device Manager, you set up device groups and add Network Functions (NF) to the groups. After you successfully add a NF, the system can communicate with the associated device and you can launch the login page for the device by way of the Session Element Manager.
- Optional—If you do not want to use the default device group, named Home, add the device group that you want. See "Configure Device Groups for Network Function."
- Configure SNMP community on each device that you plan to add to the device to Device Manager. See the device documentation.
Use the following procedure to add a Network Function (NF) to a managed device group. You can add more NFs by repeating the procedure.
The table in the following procedure displays all possible configuration attributes, but the system displays only the set that corresponds to the selections that you make in this configuration.
