Information for Oracle Interactive Session Recorder Users
The Oracle Communications Session Element Manager (SEM) supports using the Oracle Interactive Session Recorder (ISR) with the Device Manager, where you add and manage devices and device groups in SEM. SEM does not support the ISR in any of the other SEM managers.
You can launch the ISR login page from SEM and perform operations on the ISR.
SEM does not support applying work order administration to the ISR. The work order does provide the ISR as a selection.
SEM does not support the Show Details functionality for the ISR.
Note that the Managed Devices - Group View page in SEM displays the following additional controls for working with Enterprise Plug-ins.
- Add—Launch the SEM dialogs for adding Enterprise devices.
- View—View the selected Enterprise device.
- Launch—Launch the login page for the selected Enterprise device.
For information about using Device Manager, see Device Manager.
