View Serial Numbers for a Physical Device
Primary and secondary serial numbers of managed physical devices can be displayed by enabling hidden columns in the Managed Devices table.
Serial number information is pulled from a physical device through SNMP. Virtual devices return a value of N/A.
  1. Expand the Device Manager slider and click Devices.
  2. In the Managed Devices pane, click on the right side of a column header.
    The arrow icon appears with a drop-down menu.
  3. Mouse over the Columns selection and click and the column options that you want to enable:
    • Primary Serial Num—Enables the Primary Serial Number column in the Managed Devices table.
    • Secondary Serial Num—Enables the Secondary Serial Number column in the Managed Devices table.
