Session Element Manager Parts
Data Variables
Data variables (DVs) are used in offline configurations to allow network administrators to target elements that require device-specific information. All data variables must have new values to push the configuration to a device. An offline configuration requires DVs that have different values for each device that the template is assigned to support. This allows the template to be finely adjusted to the specific needs of a device and continue to provide a common baseline configuration for many devices. The template editor allows you to apply data variables to any element attribute that the offline configuration supports. A derived value can be specified when the DV that you are configuring shares the same value as another DV (dependency).
Device
A device is the atomic object that cannot be sub-divided and represents the component that does the required work. The element manager supports a network function (NF), but also manages the devices the NF contains.
Device group
A device group can contain or group NFs and devices.
Element Manager
The Oracle Communications Session Element Manager (SEM) provides alarm, configuration, fault, loading and provisioning capabilities for devices, performance management for infrastructure elements, and security capabilities.
Geo-redundant group
A geo-redundant group has active and standby devices that are not co-located.
Network Element
A network element is a manageable logical entity uniting one or more physical devices.
Network Function
An NF can be composed of device groups and devices. An NF can be simple or complex. A simple NF can be a standalone device or a high-availability (HA) pair. A complex NF can consist of device groups that further define topological constructs and complex structures for device containment.
