Deleting a Device Group
You can delete a device group (folder) from the Device Groups list with the appropriate permissions, and under the following conditions:
- Empty the device group folder and move all devices to another device group folder or delete the devices from the device group folder in order to delete the device group folder.
- You cannot delete a device group if it causes a duplicate device group in the tree hierarchy.
