Use an Offline Configuration for a Device Cluster
A common, top-level offline configuration template can be used to provision network function (NF) device cluster containing one or more groups that contain a device or a device high availability (HA) pair. An offline configuration can be created by making a copy of an existing configuration, packaged configuration, managed device configuration, or by selecting a schema from a supported software model.
For Oracle Enterprise products, offline configuration supports only the Enterprise Session Border Controller (ESBC).
