About This Guide
The Oracle Communications Session Element Manager User Guide for the Enterprise Plug-in provides the concepts and procedures that you need to know for managing the modular framework of Oracle's network session delivery and control infrastructure elements with the Enterprise plug-ins.
Oracle Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc .
Documentation Library
The following tables describe the documentation library for Session Element Manager products.
Table -1 Oracle Communications Session Delivery Plug-in Documentation Library
| Document Name | Description |
| Session Element Manager User Guide | Provides information for managing and optimizing network infrastructure elements and functions with comprehensive tools and applications used to provision Fault, Configuration, Accounting, Performance, and Security (FCAPS) support for managed network functions and their associated devices in Oracle Communications Session Delivery Manager (SDM). |
| Report Manager User Guide | Provides information about configuring Report Manager to interoperate with Oracle BI Publisher and about creating reports on Session Delivery product network devices. |
| Report Manager Installation Guide | Provides information for installing the Oracle Communications Report Manager as an addition to SDM including the Oracle database and BI Publisher components. You must add the Oracle Session Delivery product plug-in to Oracle Communications Session Delivery Manager before performing the Report Manager installation. |
| Route Manager User Guide | Provides information for updating Local Route Table (LRT) data on a single device or multiple devices. |
| Session Element Manager SOAP API Guide | Provides information for the SOAP and XML provisioning Application Programming Interface (API) client and server programing model that enables you to write client applications that automate the provisioning of devices. The web server provides operations that the system can perform on devices managed by the SDM server and data structures used as input and output parameters for such operations. |
Table -2 Oracle Communications Session Element Manager Documentation Library
| Document Name | Document Description |
| Administration Guide | Provides the following
administration information:
| Installation Guide | Provides the following
installation information:
| Release Notes | Contains information about the administration and software configuration of the ESEM feature support new to this release. |
| Security Guide | Provides the following security
guidelines:
| REST API Guide | Provides information for the supported REST APIs and how to use the REST API interface. The REST API interface allows a northbound client application, such as a network service orchestrator (NSO), to interact with ESEM and its supported product plugins. |
| SOAP API Guide |
The SOAP API guide provides information for the SOAP and XML provisioning Application Programming Interface (API) client and server programing model that enables users to write client applications that automate the provisioning of devices. The web service consists of operations that can be performed on devices managed by the SDM server and data structures that are used as input and output parameters for these operations. |
