Interface Stats Utilization Tab
| Name | Description |
| Name | The text string containing the name of the media interface. The name is the one assigned by the local device that can be a text name or a port number, depending on the interface naming syntax of the device. |
| Rx Utilization | The receive media ports that are used for media ports indexed by IF index. |
| Tx Utilization | The transmit media ports that are used for media ports indexed by IF index. |
