View Reusable Configuration Modules
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select Configuration Tools > Reusable Modules.
View the following
Reusable Configuration module table columns for the listed RCM entries:
Name Description Name The RCM name. Description The RCM description. Last modified date The date and time when the RCM was last changed. DNM Dependancy notification message (DNM). Note:
This column is not used.Created data (Hidden) The date at which data was created for this RCM. Created by (Hidden) Indicates user who created the RCM. A preexisting RCM indicates EM_SYSTEM. Category (Hidden) The product plugin vendor category. For example, SD (Session Delivery). Component (Hidden) The element manager (EM) plugin product NF component. Note:
This field populates with Default when the SD product plugin vendor category is selected.Schema version (Hidden) The software model schema for devices. Modifiable (Hidden) Indicates the following permisions: - public— Any user can modify this RCM.
- private—Only the creator of the RCM can modify this RCM.
