Upload a Configuration Schema for a Device
You can use this task to manually upload the configuration schema when the Oracle Communications Session Element Manager cannot get the configuration schema (XSD file) from the device.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).All software release configuration information is modeled and maintained in a valid configuration schema for a device so that it can be managed by
ESEM. Most often, a software release schema is matched for a device, which is required so that the device can be assigned in Configuration Manager. If a software release is not found,
ESEM attempts to get the configuration schema directly from the device (in recent device releases, the configuration schema is packaged with the release image), and put it in the database local schema repository.
If the schema for a device does not exist for a software release, the device can be added to Device Manager but cannot be managed by ESEM.- On the menu bar, choose .
- In the Upload configuration schema file dialog, select SD from the Categories table for the Session Delivery (SD) product plug-in.
- Click Browse, and navigate to a valid configuration schema file on your system.
- In the File Upload dialog, select the SD configuration schema you want to upload, and click Open.
- In the Upload configuration schema file dialog, click Upload to start the upload process.
- In the success dialog, click OK.
