Executing Work Order
Once the software upgrade work order is created and its configuration is applied, it can be executed manually (unless you previously scheduled a start date and time for it to execute).
- Expand the Configuration Manager slider and click Global parameters.
- Click the Admin tab.
- In the Work orders table, select the work order you want to execute and click Start.
- In the confirmation dialog box, click Yes.
- Click Refresh to confirm the status changes for your global parameter work order from Not Scheduled to Running.
