Modifying Global Parameters
- Expand the Configuration Manager slider and click Global parameters.
- In the GP Config tab, select the global parameter configuration you want to edit from the table and click Load.
In the success dialog box, click
OK.
The global parameter configuration name now appears below the Global Parameters icon as an expanded folder in the slider.
- Expand configuration folders in the Configuration Manager slider to access configuration elements and sub-elements of the global parameter configuration.
Make changes to the global parameter configuration as you would a single device. See your product device documentation for specific configuration instructions.
Each time you apply configuration changes in your global parameter configuration, the modifications are added to the database. They are not provisioned to your device until you execute and commit your global parameter work order. The LCV logs additions, deletions, and modifications of top-level elements.
