Predefined Work Flows
A software upgrade work order contains a predefined work flow that defines the execution procedure sequentially in a step-by-step process. As the software upgrade work order is executed, each procedural step is tracked in the Device tasks table, under the Progress column. The following sections outline the different software upgrade work-order scenarios:
